How to replace spare parts on The Fairphone (Gen. 6)
The Fairphone (Gen. 6) is designed to make repairs accessible and straightforward. Replacing individual spare parts extends the lifespan of your phone, saves money, and reduces electronic waste.
Replacing a spare part in your Fairphone requires a clean workspace and a few basic tools. Gather these items before opening your phone:
- A Torx T5 screwdriver (available in our online shop or at most hardware stores)
- A flat, clean surface with good lighting
- A soft cloth to clean phone surfaces
- Two small containers to keep screws organized
- A plastic card, guitar pick, or plectrum to safely separate components
Warning: Avoid electrostatic discharge (ESD) by wearing cotton or rubber gloves, or by grounding yourself before touching internal components. Always use a plastic object or a fingernail to disconnect board-to-board (BTB) connectors—never use metal tools.
Warning: Never insert the two long outer screws unless the back cover is in place. These screws are designed specifically for the thickness of the back cover. Screwing them directly into the frame without the cover will reach too deep and permanently damage the phone.
How to prepare your Fairphone for repair
Preparing the phone ensures a smooth repair process and protects sensitive internal electronics:
- Update your software: Install the latest software version so the phone has the necessary firmware drivers to recognize new spare parts.
- Charge the battery: Charge the battery before starting so you can test the replacement part immediately after reassembly.
- Review the instructions: Read the step-by-step guides and watch any accompanying video tutorials before opening the phone.
Recommendations before starting your repair
- Troubleshoot first: Check our troubleshooter guide to see if your issue can be resolved through software before opening the phone.
- Check warranty coverage: Contact Customer Support before ordering a spare part if your repair might be covered under warranty.
- Assess extensive damage: If the phone suffered water damage or a severe fall, have our repair center or a professional technician assess the phone first. Multiple spare parts may be affected, so replacing a single component might not resolve the issue.
Select a spare part replacement guide
Select a guide below to view step-by-step replacement instructions:
- How to replace the Fairphone (Gen. 6) battery
- How to replace the Fairphone (Gen. 6) display
- How to replace the Fairphone (Gen. 6) top unit
- How to replace the Fairphone (Gen. 6) cameras and earpiece
- How to replace the Fairphone (Gen. 6) loudspeaker and USB-C port
Frequently asked questions
For information on how to repair, dispose of, or recycle your Fairphone (Gen. 6), see below.
